Hey guys, i had that other post about what amp and now i know what to look for. This is one of the main amps i came up with.
http://www.bestbuy.com/site/olspage.jsp ... 9396976115 Those are my subs
Woofer Size 12"
Woofer Material Injection-molded polypropylene with brushed metallic surface
Magnet Size 38 oz
Magnet Type Neodymium
Continuous Power Handling 600W
Peak Power Handling 1,100W
Impedance 4 ohms
Connection Type Terminal cup
Number of Voice Coils Single
Efficiency 89dB
and this is the amp i found. http://www.sonicelectronix.com/item_6198.html
Number of Channels 2
RMS Power (4 ohms) 220 watts x 2 chan.
RMS Power (2 ohms) 280 watts x 2 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 560 watts x 1 chan.
Peak Power Output 980 watts
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power <0.02%
Speaker Level Inputs Yes
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover Yes
High-Pass Crossover 50 Hz - 500 Hz
Low-Pass Crossover 30 Hz - 500 Hz
Signal-to-Noise Ratio >98 dB
Channel Separation >55 dB
Bass Boost 0 - 24 dB
Bass/Gain Remote N/A
Fan Cooled N/A
Fuse Rating 15A x 4
Warranty 1 - year manufacturer's warranty
Do you think i would be good with that amp or do you think i would blow my subs? What do you guys think?
Thanks a lot for any help.
Mike
This amp work?
two4fifteen
If you were to buy anything from best buy, get the Alpine Type-R's the only subs worth buying there. As for an amp, look on that site for a JBL amp, should be the most bang for your buck. And check the FAQ section, it will help you tons.
well i already have the subs hooked up to an amp. They are only at 120Watt RMS right now each. I dont have all that much money thats why and i got them for really really cheap. But they sound a lot better then you would think, i no there nothing like alpine or any top brands, but they do sound pretty good. Even the audio place that installed them was like its going to be shit, look at the brand etc, but when they were done, they said it sounded a hell of a lot better then they thought.
Whats wrong with that amp? Ive read so many good reviews about that model.
