ascendant audio atlas subs...
diceman1000
Post by diceman1000 »
any body have any experience wuth these?i have somebody wanting to trade a sigle 15 in a ported box for my two eD 13Kv2's...is it worth the trade?
Damon
expect the worst,hope for the best,and take it as it comes...live life to the fullest,alway cherish your family and friends,especialy your wife and kids
HU:ECLIPSE CD8051
FS:CDT CL61A's
F.AMP:MONITOR 1 MK2.70
RS:N/A
SUBS:TWO eD 13Kv2's in 1.25 cubes ea.,sealed
SUB AMP:CROSSFIRE BMF600D@1 OHM
WIRING:SCOCHE EFX,STREETWIREZ
CAP:STINGER 1 FARAD
BATT.:OPTIMA YELLOW TOP :sub: :sub:
They use XBL technology and a "bottom less" design. I think the altas are 300rms too. I'd say if you think the 15 sounds better go ahead. IMO Ascendant audio is a lot better then eD. If you think it sounds better, I'd do it.
i havent delt with them yet but i have heard very good things. id do it.
diceman1000
the problem is that they are in cali,and i am in kansas...what do you guys think it would do if i raised the resistence os my sub,i.e.-the atlas can be ran at 4 or 6 ohms,if my amp is 600wrms@4ohms,what would it be at 6?
Damon
HU:ECLIPSE CD8051
FS:CDT CL61A's
RS:N/A
CAP:STINGER 1 FARAD
two4fifteen
Post by two4fifteen »
how can the sub be ran at 4 or 6 ohm?
racerraul
Post by racerraul »
diceman1000 wrote:the problem is that they are in cali,and i am in kansas...what do you guys think it would do if i raised the resistence os my sub,i.e.-the atlas can be ran at 4 or 6 ohms,if my amp is 600wrms@4ohms,what would it be at 6?
Damon
Around 400watts @ 6ohm... that is an educated guess & as good as any without benching it. The higher the impedance the lower the output power from the amp.
I'd keep the eD's unless you are just itching for a 15" real bad... It would likely be a move backwards in output since you have 2 12" & the SQ is definitely arguable without reputable sources to referrence. Add to that the fact that is a long distance trade... I do not see any obvious reasons to make the trade.
two4fifteen wrote:how can the sub be ran at 4 or 6 ohm?
4 real...
lol
I can see 2 or 8 Ohms... If its a dual 4 Ohm coils...
Those subs are kinda like one voice coil, then there’s another terminal post on the sub that can change it to ether 4-6 ohms. I'm not %100 sure, but its something like that.
A trade thats gonna cost money, I wouldn't say it's worth it ether. Even tho I would take ascendant audio over eD anyday, thats just because of all the crap I hear about eD.
http://www.ascendantaudio.com/archive/Atlas%2015.htm
thats is a direct link to the specs of the Atlas 15. It is essentially a single 4 ohm driver, but uses a secondary voice coil to change the QTS of the sub.
It does say something in the "advanced wiring" section about a 6 ohm driver, but it doesnt allow you to click on it.
edit: here is another link from them, showing the 2 voice coils and how the second v.c. changed QTS
http://www.ascendantaudio.com/archive/A ... wiring.htm
It says right on the page to NEVER POWER the second v.c.
