orion 2150 sx@2ohms bridged?
diceman1000
Post by diceman1000 »
anyone evere run one of these at 2 ohms bridged?is it safe?
Damon
expect the worst,hope for the best,and take it as it comes...live life to the fullest,alway cherish your family and friends,especialy your wife and kids
HU:ECLIPSE CD8051
FS:CDT CL61A's
F.AMP:MONITOR 1 MK2.70
RS:N/A
SUBS:TWO eD 13Kv2's in 1.25 cubes ea.,sealed
SUB AMP:CROSSFIRE BMF600D@1 OHM
WIRING:SCOCHE EFX,STREETWIREZ
CAP:STINGER 1 FARAD
BATT.:OPTIMA YELLOW TOP :sub: :sub:
That being an older orion you might be able to pull it off, but I am not sure if I would want to try.
http://www.orioncaraudio.com/alley/pdfs ... ca2gen.pdf
Orions own pdf states 2 ohms stereo. If you bridge it the amp would see a 1 ohm load. So that might be pushing it.
See if you can catch KIKI, he could tell you for sure.
hmmm depends on if what the load is is this just small bursts of bass or daily driving?
OnYrMrk
Post by OnYrMrk »
As a former Orion Dealer, I feel I should warn you. A 2 ohm load is no problem for the 2150, but a 1 ohm load is completely out of the question. You should get about 600 watts out of that bad boy that way. and it is 4ohm bridged to get a 2 ohm load I believe
OnYrMrk wrote:and it is 4ohm bridged to get a 2 ohm load I believe
Yep, bridiging it at 4 ohms will make the amp see a 2 ohm load
diceman1000
it would be daily...two single 4 ohm subs in parallel
Damon
HU:ECLIPSE CD8051
FS:CDT CL61A's
RS:N/A
CAP:STINGER 1 FARAD
then based on what they are saying the answer is no........
What subs are you using? Why not just use it in stereo?
diceman1000
well,i've got somebody over at icix wanting to trade his single 4 ohm flat con o's,400-900wrms,for my 13Kv2 dual 4's,150-300wrms...the o's are much better subs,but with them beung single 4's i can hardly power them with the amp i have,the orion
Damon
HU:ECLIPSE CD8051
FS:CDT CL61A's
RS:N/A
CAP:STINGER 1 FARAD
I've done it before and it worked, but I don't recommend it.
