enclosures
pbstud1085
- Member
enclosures
so i just want to know how much bump you gain and how much quality you lose from using a bandpass compared to a ported.
thanks
thanks
You can get about a 6-10 dB gain with a PROPERLY DESIGNED AND BUILT bandpass.
This doesnt mean the ones at Best Buy!
They only play choice frequencies good. I would avoid...
it really depends on what order the box is and how it's built.
generally the more gain you get from a BP box, the higher it'll be tuned, so the more SQ you'll lose. Generally you'll see zero to six decibels of gain over a ported box, on average. The problem is that most 4th order boxes are tuned around 45-65Hz, and quite frankly that sounds like crap if you want any sort of deep bass.
bandpass, like ported boxes, roll off like a brick wall below the tuned frequency.
pbstud1085
- Member
pbstud1085
- Member
lets see....blackhawk sounds good, nice and tight...........metallica, motley crue of course, pantera,highly recommend cowboys from hell............anything by waylon jennings or any of the outlaws stuff.......faster pussycat, merle haggard, george strait of course....... dont know any rap stuff, im sure there is doc somebody or p something or other though that someone will recomend. although i do like the autosound 2000 test disc for setup and there is a bass mekanic disc i use at work
pbstud1085
- Member
