is my deck capable....
MrSo0h0o
Post by MrSo0h0o »
is my deck capable of hadling the bi-amping of my 4 ch amp? (can i control the channels to the extent i need it to)
i know this may take up some time to check out, but im not totally sure if its possible with some of the fine-tune settings and i dont want to experiment and blow a tweeter.
here is the owners manual. http://www.pioneerelectronics.com/pio/p ... 321970.pdf
spare my feelings and take a look at section 8 of the manual or pdf pages 32-38.
i appreciate the help in advance as i know this is a pain in the ass but i will be ever so greatful.
Randy
If the amps or the headunits crossovers will work as adjustable HPF for the front, and rear, then yes. They need to be adjustable to around 80 herts and around 2K herts.
Or
You need a component set that has 2 inputs on the crossover.
If you don't have either, you need a active crossover.
MrSo0h0o
Post by MrSo0h0o »
yea, my HU has both a LPF(50-125hz) and a HPF(50-125hz), but there are also settings that get deeper into things which i am not sure if they can do the trick.
well, the crossover for my components is such a dinky one. its the size of a walnut or so lol.. it has 2 inputs(2 screws?) and 4 outputs?)+/- woofer, +/- tweeter) i dont think this would do, would it? here is the link to the component set manual for reference: http://www.diamondaudio.com/products/pd ... 052004.pdf
MrSo0h0o wrote:yea, my HU has both a LPF(50-125hz) and a HPF(50-125hz),
You just answered your own question, no it will not work.
MrSo0h0o wrote:well, the crossover for my components is such a dinky one. its the size of a walnut or so lol.. it has 2 inputs(2 screws?) and 4 outputs?)+/- woofer, +/- tweeter) i dont think this would do
I hate to say it,but this won't work either. If it was biamp capiable, it would have 2 inputs, (4 screws) Looks like you are back to purchasing another crossover.
MrSo0h0o
Post by MrSo0h0o »
ahh i was looking for a cheaper way out and hoping that my HU had enough capability. oh well.. dont really have the money to get another crossover so ill stick with what i got. unless u guys know of a quirky way to hook up a component set to a 4 ch amp another way? lol
Not unless you want to fry some tweets. I am pretty sure you will be happy with it like it is.
You could always run the extra speaker wire while you have it apart, so when you do have the money you could add the crossover later.
MrSo0h0o
Post by MrSo0h0o »
yea.. once i get all my wiring for my 2nd amp, im gonna dedicate a day to totally rewire my car.. the first time i did it i was in a rush to get it finished because i was late for work. this time around i can take a full day during the week. hopefully i can get all my wires together too, because its a mess!(not hazardous)
