PXA Weatherproof Amplifiers: High-Performance Audio in Any Weather
Kicker, a leading brand in the car and marine audio industry, has recently launched the Kicker PXA Weatherproof Amplifier series. This series includes four models - the PXA300.1, PXA400.4, PXA600.1, and PXA1000.5 - that are designed to deliver high-performance audio in extreme weather conditions and provide reliable and durable performance in outdoor environments.
One of the key features of the Kicker PXA Weatherproof Amplifiers is their IP (Ingress Protection) ratings. These amplifiers have both an IP66 and an IP67 rating. The IP66 rating indicates that the amplifiers are completely protected against dust ingress and powerful water jets, while the IP67 rating means that they are also dust-tight and can withstand immersion in water up to 1 meter for 30 minutes. This makes them highly resistant to water, moisture, and other debris that could damage the amplifier, making them suitable for use in even the toughest outdoor environments.
The Kicker PXA Weatherproof Amplifiers are Class D amplifiers that can deliver up to 1000 watts of power, depending on the model. They feature a conformal-coated circuit board that protects against moisture and corrosion, making them ideal for use in boats, ATVs, and other outdoor vehicles. The amplifiers are also equipped with stainless-steel mounting brackets that are rust-resistant and can withstand saltwater corrosion.
The amplifiers feature variable high-pass, low-pass, and subsonic filters, allowing users to customize the sound output to their preferences. They also have high- and low-level inputs, making them compatible with almost any audio source.
The PXA300.1 and PXA600.1 are monoblock amplifiers that deliver up to 300 watts and 600 watts of power, respectively. The PXA400.4 is a four-channel amplifier that delivers up to 400 watts of power, and the PXA1000.5 is a five-channel amplifier that delivers up to 1000 watts of power. These amplifiers are designed to operate in extreme temperatures, from -20 degrees Fahrenheit to 150 degrees Fahrenheit.
With both an IP66 and an IP67 rating, the Kicker PXA Weatherproof Amplifier series is a highly reliable and durable solution for audio enthusiasts who want to enjoy high-quality sound in outdoor environments. These amplifiers are compact, versatile, and built to withstand harsh outdoor conditions. Their superior performance, weather-resistant features, and customization options make them an excellent investment for any audio system. The added benefit of their IP66 and IP67 ratings means that users can rest assured that their amplifiers are well-protected against water, moisture, and debris, delivering high-quality sound in any environment.
This article was AI generated and the information provided has not been verified.
