Pairing Phone With Car Radio Kenwood DPX504BT ?
bmck88
Post by bmck88 »
Just purchased a Kenwood DPX504BT. The dealer helped pair my cellphone with the new car radio. However, I want to add a 2nd phone to be paired. The manual lists instructions for pairing the 1st phone . The manual stated "when pairing a phone the 1st time" but seemed
lacking in detail what to do if adding a 2nd phone. Hoping for a step by step procedure or
even a video. The radio has numerous features and options.
A bit overwhelming for a novice.
Thank you. bmck88
viewcart
Re: Pairing Phone With Car Radio Kenwood DPX504BT ?
Post by viewcart »
CA outputs aren't meant to power speakers, they are meant to provide a low level signal to an amp. In regards to the bluetooth, verify you have any phone side EQs or application EQs set off and the phone volume up. Also consult your radios owners manual and verify that you don't have any volume offsets set for different sources.
bmck88
Post by bmck88 »
Thanks for your reply. Sorry too complicated for me. I was looking for a step by step explanation. As mentioned, I do not fine the manual that helpful. bmck88
bmck88
Post by bmck88 »
Finally I have managed to access the phonebook on my Kenwood DBX504BT radio. By pressing the phone icon on the screen , the phone call history pops up and from there by rotating the
dial on the screen I can scroll through the list of contacts and make a call . Now the only issue is exiting the phone screen and getting back to the radio options, Sirius, FM etc.
Clicking on the radio band section does not always respond. I have not used the radio enough but at least making headway. Thanks for all replies. bmck88
bmck88 wrote:Finally I have managed to access the phonebook on my Kenwood DBX504BT radio. By pressing the phone icon on the screen , the phone call history pops up and from there by rotating the
Yay!
Glad you were able to get it working and thank you for reporting back with how to do it.
