Best Amplifier for Cerwin Vega components
stardamore
Post by stardamore »
So I've searched everywhere and can't, for the life of me, find out which amp would be perfect for my Cerwin Vega xed components. Can you guys help me out? The specs are:
Model: Cerwin Vega xed65C MKII
75W RMS
420W Peak Power
Impedance: 4 ohm
Sensitivity: 88 dbwm
Can someone please tell and explain what spec amp should I get to get the maximum performance out of these speakers? I'm preferably looking for an economical but good performing amplifier.
Thanks!
Re: Best Amplifier for Cerwin Vega components
stardamore wrote:So I've searched everywhere and can't, for the life of me, find out which amp would be perfect for my Cerwin Vega xed components. Can you guys help me out? The specs are:
75W RMS
420W Peak Power
Impedance: 4 ohm
Thanks!
welcome to the forum
Just going by the specs you listed.
Ignore the peak power, so you'll want an amp around 75-100watts per channel.
Do these speakers come with a crossover? If not, you can get an amp that has an adjustable one built in.
That's really about it, just stick with known brands and you'll be fine.
stardamore
Chris from Washington wrote:welcome to the forum
Yep, they have a built in crossover. The thing I have a hard time understanding is what should be the impedance of the amp, what's bridged or unbridged? Can you point me to any specific amplifier which would go well with these components and is known to be good quality?
stardamore wrote:Yep, they have a built in crossover. The thing I have a hard time understanding is what should be the impedance of the amp, what's bridged or unbridged? Can you point me to any specific amplifier which would go well with these components and is known to be good quality?
Sure,
Bridging is when you take 2 channels and basically merge them together, this is usually done with subwoofers. So since these are components you don't have to worry about bridging.
You'll want an amp that can go down to at least 4ohm stereo. Which I would assume any amp on the market can do. Most can go down to 2ohms stereo.
Are you just running 1 set of these? If you're running more than one set, and only going to have one amp. You'll want an amp that can go down to 2 ohm stereo. Since you'll be running 2 sets per channel. which would give you a 2ohm load.
Do you have any amps in mind? I could look to see if something like that would work.
stardamore
Chris from Washington wrote:Sure,
So I'm running one set of these and coaxials in the back doors as well. Don't know the exact specifications but they're cadence coaxials. Allow me to provide some background. I started off with a cheap Chinese amplifier, my main goal was to listen to high SPL. The components and coaxials ran pretty well with crisp and loud sound on the chinese amp. But after a month, the right tweeter blew. I changed the whole component set again, then after a month the left tweeter and components blew. So I bought the whole set again a third time but this time, the guy I bought it from offered me a good quality amp as well. The thing is is that amp literally has no specifications on it. And ever since I've put it in, the sound of the whole system sounds extremely muffled, If I crank the volume up to 100% the sound is still muffled and the components start crackling. My guess is is this amp is rated at very low power, which is why the sound is so crap. On a sidenote, I have another amp as well which powers 2 Pioneer D4 subwoofers. It's a chinese amp as well, the company is Rock Mars.
Here is what I would do.
Since you're running rear speakers too, find yourself a 4 channel amp.
Then you can run your front/rear and maintain fading control from the deck.
I would avoid all those Chinese knockoff amps, you'll just keep having trouble and end up spending more money on replacing or troubleshooting them.
stardamore
Chris from Washington wrote:Here is what I would do.
Yeah, that's what I'm thinking as well. What amp would you recommend for this setup in the range of $100-$200?
For a daily driver setup, something that is not meant to be a high SQ type of install.
Anything from the major companies will work, and also consider used. I've purchased used amps and never had an issue.
https://www.ebay.com/itm/Rockford-Fosga ... k:3 :p f:0
If you wanted to go with an old school amp
https://www.ebay.com/itm/OLD-SCHOOL-ROC ... :82 :p f:0
Basically just stick with known brands
Pioneer
Fosgate
MMATS
etc.
Report back with what you decided to go with
