is it possible?
xxwikkidxx
is it possible?
can i wire 2 12in 4ohm single vc and 1 12in 4 ohm dual vc sub to my monoblock amp?
- Chris from Washington
Re: is it possible?
Hi,
Welcome to the forum.
What type of amp, need to know what the amp can handle for a load.
I personally don't like to mix/match subs like that, but technically if your amp could handle it. You could wire the 2 SVC's in parallel to get a 2 ohm load. The wire the coils on the DVC in parallel which would make 2 ohm. Then wire the DVC in parallel with the SVCs and that would give you a 1 ohm load.
Re: is it possible?
Even if the amp can handle it, I wouldn't suggest it. The subs are going to have different suspensions, and different specs.
So one subs x max on a note can and will be different than the others subs x max on the same note. That will cause constructive and destructive interference between the sound waves.
colemanyoungerinalaska
Re: is it possible?
you probably could i wouldnt
wouldnt run them in shared airspace if i did it either
