So I have a kenwood stereo in my 1979 Datsun 280zx and it's wired to a MBQUART ONX4.60 amplifier but it seems as if there's no power going to the amp. Please help!
I swear I have everything hooked up correctly!
Northwest_280zx
- Chris from Washington
Re: I swear I have everything hooked up correctly!
Welcome to the forum.
Do you have a multi-meter? Do you have 12v on your main power wire? are you getting 12v on the remote wire?
I would check those, then the ground. Then also make sure all your fuses are good.
A quick check.. use a jumper wire between the power + and the remote turn on terminals on your amp to see if it turns on.Northwest_280zx wrote:So I have a kenwood stereo in my 1979 Datsun 280zx and it's wired to a MBQUART ONX4.60 amplifier but it seems as if there's no power going to the amp. Please help!
Sent from my SM-G935U using Tapatalk
