hi guys, i have polk mm6.5 in my ranger currently. One of the mids stopped working. I have about two weeks left on the warranty, and im not expecting polk to honor it (i feed them 80 watts rms and listen to them loud, but not distorted.
My search now is for a set of mid ranges to use with the cross overs and tweeters already installed (the polk mm) id really rather not spend $200+ on another set of polks. i wouldnt be opposed to buying a used polk mm, but havent seen any available. Any good choices out there for a set of mid ranges? I cross them over at 80 hrtz on the low end.
2 ohm 6.5" mid range speaker choice
JoshKeller
- Chris from Washington
Re: 2 ohm 6.5" mid range speaker choice
Hi,
Well I was also in the market for some new mids, and after doing some research I found a lot of talk about Hybrid Audio.
I just purchased a Unity U61-2's and hopefully will have them installed soon, still need to make new kickpods.
but they are getting a lot of praise that I've seen, so I'm really looking forward to hearing them.
Might be something to consider, they have other lines too some cost more and others less.
