Pioneer Deck Installation Trouble???
rissraider2211
I am trying to install a Pioneer DEHP6700 in a 98' Chevy Silverado. The problem is there is absolutely no power getting to the deck. I have tried almost every wiring option.
The Chevy wire diagram reads:
MEM - Orange
PWR - Yellow
GND - Black
The Stereo Diagram reads:
BATTERY - Yellow
ACC - Red
GND - Black
I assumed that Orange was the one that went with the red, Yellow-Yellow and Black-Black. NOTHING!! I even went out on a limb that the colors were mixed, and tried the Yellow-Red. STILL NOTHING! I checked the stereo fuse and it is good. What do you suggest???? This is frustrating cuz it is sooooo simple, but i can't get it to work. Thank You!
MEM - Orange
PWR - Yellow
GND - Black
BATTERY - Yellow
ACC - Red
GND - Black
Are you sure that the orange wire is the ACC switched wire? You can try putting both the Yellow and Red from the head unit to the truck's yellow and see if it comes on.
The deck may require itself to be grounded. Is the unit attached to the truck's metal in anyway?
1998 Chevrolet C/K Pickup Stereo Information
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Front Speakers 6 1/2" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 4" x 6" Side Pillar
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Mithrandir
what did you do, cut the factory plug off?
