What Amp Setup Would Work Best
Nasty Nate
Im getting two Alphasonik 15s 800 series and was seeing what kind of setup would work best? Im learning but also lost! Iv looked at alot of the audio control setups and im still not sure of all the equipment im going to need.
What kind of set up are you going for? SQ, SQL, SPL?
How much do you want to spend?
I would stay away from alphasonik, as they are not ranked very high in the car audio industry IMO.
(edit: as long as u havent gotten them yet)
Maybe if you give us a clue on what you want and how much you want to spend we can steer you in the direction of a better set up
Oh yea...and welcome to the boards
TEDD
TEDD
Nasty Nate
Well, i'm glad you haven't gone with the Alphasoniks, because we can help you get something MUCH better for the budget you're in. I've got a few questions for you which will help us all to guide you on the right path:1. What vehicle will this be going in and would you like to stick with the stock alternator to run your sub(s) or are you willing to upgrade if needed? 2. Do you plan on competing or is this strictly for daily driving? 3.What types of music do you listen to on a regular basis?
Alphasonik is owned by Audiobahn. 'Nuff said :) . As much as I love the way their amps' (Alphasonik's) look, I'd never buy one.
What exactly do you have currently? When you refer to "system" do you mean amps and subs or an entire system?
If just amps and subs, I'd go with one DD 9515e and power it with a Rockford Fosgate Power T10001bd. You could subsitute an Mmats Juggernaut for the 9515e if you wanted.
For a dual 12" setup, I'd go with Elevation Audio Pro's (same amp). Or instead, a single Elevation Audio Execution X15 (also with same amp). You could also get a pair of Memphis M3Mojo 15's.
Nasty Nate
Im getting a 1982 Bronco it has lots of room! Im not sure about the alternator and im willing to upgrade if needed. I want to show it off of course so maybe competing. And i listen to Rap, Rock, and Dance. So i might need an EQ? Yes and sadly Im going to need a entire system! And thanks for the info.
Also have any of yall heard of sonicelectronix.com because they have really good prices and was seeing if its a shady site.
Nasty Nate
kevinberry1
Nasty Nate
