Help Alphasonik Vs ElevationAudio ?
water
Post by water »
Ok here its my question I have an alphasonik PMA300CA 2-Channel High current Amplifier and i want to know if the ElevationAudio DX300.4 4-Channel Amp its better than the one i have now?
Here are the Spect on the ElevationAudio
Alphasonik Spect look like this
Features:
* 150 watts x 2 @4ohm
* 270watts x 2 @2ohm
* 450 watts x 2 @1ohm
* 475watts x 1 @4ohm
* 780 watts x 1 @2ohm
* 900 watts x 1 @1ohm
* Bridgeable
* Hour Meter
* Remote Mount PMA100V Digital Volt Meter
* Remote Mount PMA10B Bass Boost Control
* Heavy Duty One-Piece Extruded Aluminum Heat Sink
* Beveled Clear Acrylic Protective Cover
* Tiffany-Style RCA Jacks
* Parallel Line-Out RCA Jacks
* Removable Aluminum Side Covers Conceal Control & Terminal Panels
* MOSFET High-Speed Switching Power Supply
* Milspec Double-Sided Glass Epoxy Circuit Board w/ Through-Hole Plating
* Heavy 4 oz. Pure Copper PC Traces at All Preamp & Amplification Stages
* Solid Brass Nickel-Plated Terminal Blocks (PMA800 & 1000HCA
2-Gauge Power, 8-Gauge Speaker) (PMA150, 300, 600 & 640HCA
4-Gauge Power, 8-Gauge Speaker)
* Variable Low-Pass Filter: 50Hz~250Hz, 24dB/Octave
* Variable High-Pass Filter: 50Hz~250Hz, 24dB/Octave
* Variable Subsonic Filter: 20Hz~60Hz, 24dB/Octave
* Variable Bass Boost @ 45Hz: 0 ~ +18dB
* Variable Phase Shift: 0~180¾
* THD: < 0.05%
* Signal-to-Noise Ratio: >100dB
* Frequency Response: 5Hz~50kHz
* Input Impedance: 10k©
* Input Sensitivity: 200mV~8V
* 4-Way Protection Circuitry: Thermal, Short Circuit,
Overload & DC Offset
* Cooling Fan(s)
* Dimensions (W x H x U 91/16 x 2 5/8 x 16 1/6
Im a newbie when it come to this. But i read some where that the ElevationAudio its preaty clean and clear audio. if anybody can commend on this please
MobileAudio219
Post by MobileAudio219 »
water wrote:Ok here its my question I have an alphasonik PMA300CA 2-Channel High current Amplifier and i want to know if the ElevationAudio DX300.4 4-Channel Amp its better than the one i have now?
Features:
* Bridgeable
* Hour Meter
* THD: < 0.05%
* Cooling Fan(s)
EA is better than what you have now.
Depends on what your goal is.
You have a 2 channel amp with more rated power than the 4 channel amp.
So whats your goal?
The EA amp probably is a better build over the Alphasonic. Alpha is a "has been" company of the past. EA isnt exactly the best thing in the world either. Ive heard a decent amount of negative about them so Im not sure if I would buy them or not. Probably not if it was my money.
water
Post by water »
Sorry forgot to mention. yeah its going to power 4 LC6 from Elevation audio
I replace my factory speaker for 4 of this LC6 also added 4 tweeters
Im nah sure if the tweeters are getting power from the amp. I had some one doing it for me
:unwell028
WTH tweeters are those? E Bay "specials"?
water
Post by water »
Ryan from Ohio wrote: :unwell028
yeah. well i got that pic from ebay. I didn't buy my from ebay the guy whos doing it bought it for me i don't know where
