Need help with this.
carolina19
Post by carolina19 »
How do I determine what the port tuning is on a ported box that I have. My subs blew and I need to figure out the port tuning to this box so I can get subs that will work with it.
NorthQuad
Post by NorthQuad »
Here are some specs on your box. Measure the width and legth of the port.
One of the guys here might be able to figure it out for you.
http://www.sonicelectronix.com/item_163 ... 20B5D.html
dave.
NorthQuad
Post by NorthQuad »
It does look like a fairly well made box though. Just my opinion.
dave.
carolina19
The length of the port is just about 15 inches long and is almost exactly 6 inches wide for the majority of the port but it rounds off and widens out on both ends. Thanks
carolina19
btw im running a class D 1200w peak amplifier.
NorthQuad
Post by NorthQuad »
Ok, so the dimensions of your box are 15-1/4" top depth x 18" bottom depth x 32" wide x 16-1/16" high with a round port width of 6" and length of 15". Box is built out of 3/4" mdf board.
One of the car audio ninja guru's will probably jump in here and tell you what you have.
I'm not that good.
dave.
NorthQuad
Post by NorthQuad »
carolina19 wrote:btw im running a class D 1200w peak amplifier.
RMS rating is what is needed. Which brand and model?
dave.
scotts1000rr
Post by scotts1000rr »
3.87@32ish I beleive Anybody else get that?
carolina19
xm-2002gtr is the model number its an xplod class d amp and I believe its 500w rated power. The box is also set up to run a series or parralell wiring system.
loudwagon15s
Post by loudwagon15s »
lol in the specs of the box they dont even bother telling you what its tuned to
