Have a cool ride? Then show it off on our website ! All vehicles welcome!
MrSo0h0o
Posts: 569 Joined: Wed Oct 13, 2004 7:58 pm
Post
by MrSo0h0o » Tue May 19, 2009 11:45 am
Hey guys, the overcurrent protection light is on on my Xtant 301A amplifier. What could the cause of this be? Ground is good. How can I stop it from drawing too much current?
Posts: 9312 Joined: Wed Aug 03, 2005 11:00 am
Post
by Bwcad1 » Tue May 19, 2009 11:50 am
MrSo0h0o wrote: Hey guys, the overcurrent protection light is on on my Xtant 301A amplifier. What could the cause of this be? Ground is good. How can I stop it from drawing too much current?
Increase the load to decrease the power.
MrSo0h0o
Post
by MrSo0h0o » Tue May 19, 2009 12:17 pm
Bwcad1 wrote: Increase the load to decrease the power.
I checked the resistance at the speaker outputs and also at the subwoofer box terminals and it showed 12 ohm. The subwoofer is currently wired for 4ohm. Is this a problem?
Posts: 13308 Joined: Fri Mar 17, 2000 12:00 pm
Post
by Ryan from Ohio » Tue May 19, 2009 12:28 pm
lol, you measured the DC resistance of the amp?
That has no affect.
You can check your DC Resistance on the sub. It must be out of circuit though.
MrSo0h0o
Post
by MrSo0h0o » Tue May 19, 2009 12:44 pm
Ok so if I find a resistance anything other than what I am wired up for, then the subwoofer is toast?
Also, even though I disconnect the speaker wire from the amp, I still get the overcurrent light. This might mean the amp is shot, right?
Post
by Bwcad1 » Tue May 19, 2009 1:01 pm
Yes. What is the lowest stable load and what load were you running at.
MrSo0h0o
Post
by MrSo0h0o » Tue May 19, 2009 1:12 pm
Bwcad1 wrote: Yes. What is the lowest stable load and what load were you running at.
the lowest stable load the amp could run at was 2ohm. I was running at 4 ohm.
Post
by Bwcad1 » Tue May 19, 2009 3:39 pm
got some bad news for you bro...
Posts: 4771 Joined: Tue Jul 04, 2006 7:21 am
Post
by cargodz » Tue May 19, 2009 3:43 pm
^ Yup, sounds like you might currently have a pretty paper weight.
MrSo0h0o
Post
by MrSo0h0o » Tue May 19, 2009 4:33 pm
yeaaa i figured as much... just curious, what would cause such a thing? just a regular failure of the amp and/or the sub, or is it something i could have done?
