This is the message I got from him.
My reply:" wrote:Hey man I just got some bought some speakers and I hooked up the amp it works.. but it cuts out after alittle play time. It doesn't go into protection. I know it's not the speakers because i hooked them up in my buddy's car and they worked fine. any idea's?
Whats the ohm load you are feeding the amplifier?
Have you messed with the gain settings any?
His return:
And my reply:" wrote:turned gain down to half way it's running high 1's for ohm like 1.7 1.9 specs say it should run 1 ohm stable
Yeah, I was running it at 1 ohm during the time it was used on the Hifonics.
If your around tomorrow morning, bring it by, and I can check it out.
Have you checked the fuses on the side of the amp?
So yeah, I know the amp is good. Sounds like he is feeding it around a 1.7-1.9 ohm load. First thing I'm going to check is the actual ohm load he is feeding it. Then I'll check the connections. I'll move onto the actuall adjustments on the amplifier, and then I'll check the HU (who knows, he may have the BASS/SUBWOOFER setting maxed out).
I just don't know what could be wrong with it.
Any suggestions?
