Silicon
Silicon
Sup guys, well i just double checked my box to make sure it was all sealed. I found a couple of things that needed another bead of silicon.
I've heard how silicon odors eat away surronds on subs (or something of that manner) is this true?
I was under the impression its fine to use silicon if you let it fully dry before putting the subs in. If this is the case how long do i have to wait before i can safely put my subs in?
Thanks in advance,
Dave
Thanks in advance,
Dave
Use the silicone.
Ive never had a problem with it yet, ever.
From crutchfield...To make double sure that everything was sealed up, we waited for the glue to dry and ran a bead of silicon caulk over all of the box's internal seals. We used a hand-held tube of caulk, since it would be tough to get a caulk gun down inside the box at this point. Let the caulk cure for 12-24 hours before putting the subwoofer back in. Some silicon caulk releases acetic acid fumes while curing, which have the potential to destroy subwoofer surrounds.
Step 9.
Just as long as all of it feels dry and you don't smell any, it's cured.dmeyer07 wrote:The box is in the car already, and i can't have anything open as it is raining out.
I've done this before and hadn't had any problems with fumes, but will it still cure in 12-24 hours?
The fumes *can* mess up a sub's surround (i.e. eat it away), but some surrounds are made with material that isn't sensitive to the fumes of silicon.
Ditto on the Liquid Nails, I used it on my most current box instead of silicon. It beats buying a tube of glue and a tube of silicon!
