Hifonics TXI 6408 or ZXI 6408?
jgs07
Post by jgs07 »
i want one to power my alpine components (SPR-17s). i mean they both put out the same power. whats the difference between them?
Funny you should mention those, as I just posted those in your other thread...
The Titans are Hifonics entry level amps and the Zeus are the step up (slightly better quality).
jgs07
Post by jgs07 »
hey michael i was reading up on those amps and they say in the description that 4 gauge ground and power wire are required. but i should be good with 8 gauge wire right?
If you're planning on stepping up to one of them vs. the other lesser model Titan you listed then you may want to contact KnuKoncepts and see if you can upgrade from the 8 gauge to the 4.
Do not skimp on wire... you can blow up your amps or burn your car to the ground... wire is one of the most important and often overlooked issues in an install. My mbquart has 4 gage connections and i ran 0.
Remember this
http://www.caraudiocentral.net/forums/s ... hp?t=10368
you dont want to go through this shit again do you?
JUST DO IT RIGHT THE FIRST TIME SAVE YOUR MONEY AND THE BULLSHIT.
jgs07
Post by jgs07 »
yeah i know but i already ordered that 8 gauge kit from knukonceptz shit and its coming this thurs
Y did you order it without first checking to make sure its the right size for your amp?
jgs07
Post by jgs07 »
becuz i talked to michael and a guy at a shop and they said 8 gauge is what i need for a four channel amp. the amp is only putting out 600 watts rms
jgs07 wrote:becuz i talked to michael and a guy at a shop and they said 8 gauge is what i need for a four channel amp. the amp is only putting out 600 watts rms
Wow...
I think Michael is loosing it... Especially after the last few things i heard.
jgs07
Post by jgs07 »
my bad i dont mean to make michael look bad
