This is the starter cable...I built this several years ago because the stock cable did pretty much the same thing. I thought I had routed it far enough from the exhaust manifold, but obviously not....
It's been in place for a good number of years and both ends started out the same color. The end seen with the connector attached to the starter (the other end to the battery of course), was routed as the stock one was close to the exhaust manifold. Over the years, the heat apparently got to it and made the insulation brittle and cracked, inside the cracks, the copper strands are corroded. I had him replace the cable with a length of welding cable of the same gauge and routed it around the oil pan and paralleled the negative cable that attached to the block. Something I could have done, but since the car was already disabled in the shop...
I should know in the next few days or weeks if we fixed this problem.
