I have a jbl 4 channel front channel up to my comps, rear up to the sub. I miss being loud, so i bridged each channel onto each coil of the sub (dual 4) and a kid i met at college gave me a shitty legacy 2 channel for helping him install an alt that i was going to hook up to my comps. With everything off, i hooked up power, remote, and ground to the legacy (everything still hooked up on 4 channel) When i put the fuse in on the legacy, i noticed that the sub started to pulse like crazy
wtf? alt whine
loudwagon15s
wtf? alt whine
I'm somehow getting alt whine like crazy, and how it happened is kinda complicated so here goes,
even though the only connection between the sub and the legacy was the remote wire, pos & neg (off of a distro block) I unhooked the legacy, and went back to my old setup, and when i did i got terrible alt whine while the engine was running (no wires were moved) If i hook up the rca's one at a time, the two that were hooked up to the jbl (front and sub) cause alt whine, however the pair not hooked up (rear) caused no alt whine, and a combination of the rear rca and anything else causes the alt whine to stop. (oh, no alt whine while car is off, or rca's unplugged, or rear rca's) So now i have no idea how to fix this, i've heard of peoples grounds going out on their rca's but dont know how to fix the problem.
- MobileAudio219
loudwagon15s
- MobileAudio219
Recheck them...loudwagon15s wrote:i dont think i have bad rca's or loose grounds, i just went through all my wireing when i was having voltage drops, i think somethin is f'd up with my hu
pull youre headunit and put the rear rcas to the front, if it stops than that tells you it's probably a bad rca...
I'm still thinking its a ground issue...
loudwagon15s
loudwagon15s
- swimmerdude
