also, my deck just spits cd's out cuz i took it apart cuz it had my soad cd in it when i pulled it out to put my pioneer in.Jonathan wrote:"the rca's were new never used. it doesn't matter which channel the rca's are plugged into right as long as their hooked up to the hu and amp? i do have another set already ran to my hu and back to the amp cuz i do have another amp i will use for my components. but there could be something wrong with my hu cuz everytime i went to push a button on the deck, i could hear "thumping" coming from the woofer. maybe it has somethign to do with the rca's.
i do have a jvc headunit but i don't have the wire harness for it."
If you have a voltmeter or know someone who does, you need to check the voltage output of the RCAs to see if it's decent output. With a 0db reference tone you should be able to get around 2V, with music it'll be much lower than that, though. You should still be able to get a decent voltage output from the RCAs.
orion 2500d and jl13w7 help
dkguitarist
- Member
dkguitarist
- Member
well take out the sub, and check the ohm load. Check your wires for the HU, and all the way to the amp. Make sure nothing is loose. make sure your wires are correct from your amp to the sub. I know you say you checked it, but take your time and check carefully.
dkguitarist
- Member
dkguitarist
- Member
