New Build Help
whataburger
DopeCracker
OK, I finally went to the shop. For a ported box with the Kicker 2x 12" L7 w/ Ported Box, it will run me about $599.99 and another $50 for labor (This also covers amp install). When I decide on a radio, a standard receiver will cost $30 to be installed. The guy said I should get one of the amps in the store, which is a Power Acoustic A1800DB for $329.99. I am kind of skeptical about buying that. I also don't think I want to spend a bunch on an amp. I am not sure if I should buy the Kicker ZX1500.1 amp. I am pretty sure I am going to the buy the HiFonics Zeus 6.5" comps.
So to sum up:
I am pretty sure I am going with the Kicker 2x 12" L7's w/ Ported Box.
I am pretty sure I am going to get the HiFonics Zeus 6.5" Comps.
I could use some recommendations to what would power the subs, because I am unsure of the Power Acoustics' Amp.
I kind of want a screen for the dash, but I do not know if I want to spend the money.
Thanks in Advance
So to sum up:
Thanks in Advance
Out of the Power Acoustik line up... I would recommend the new Gothic series amps... if you go with the Kicker L7 Dual 4ohm voice coil 12"s, then you may want to look at the Gothic OV1-3000 (1700wrms @ 1ohm).
As for a more affordable h/u with video... Look at the Jensen VM9412, Jensen has stepped up nicely in the last few years and offers some good quality features at a good price :)
DopeCracker
Well I don't know what all your local shop carries and at what price ranges... P/A is alright, but better can definately be had... If you fill us in on what lines they carry then we could give you a better idea of what might fit the bill better...DopeCracker wrote: Also, would you suggest another brand in a similar price range that is better than Power Acoustiks for amps?
Oh and I must say that I am glad to see you supporting your local shop
DopeCracker
See if they can get you Hifonics... The Brutus BXI1606D to be precise. It'll be a little more than the P/A amp, but still far less than the Kicker amp and is a far better amp
DopeCracker
Ok, got the final quotes on everything, $299 for the BX1606D HiFonics Amp, $550 for the 2 12" L7's with ported enclosure, $380 for the Jensen VM9412 in-dash screen. He said he was unable to get the HiFonics Zeus components for some reason. Having said all this should I ask him if I can order the Zeus components myself and see if they could just install them as I have heard these are highly recommend? If not, what path should I take in getting speakers? He said he had some kicker speakers(not too sure about them though), polk audio speakers. Final question for this post, should I get the subs in 2 Ohm or 4 Ohm impedance?
Thanks so much guys, I am grateful for you wisdom!
breakjunki
