Kicker ZX1500.1 Overheating?
two4fifteen
Ampresearch
Some amps do get really hot and I've had alot of people ask about why their large kicker amps get so hot, even with upgraded wiring, bat, and alt.
Simple solution really put the amp up on some small blocks so air gets under it, then rather than paying the money for an amp fan, go to your local computer shop and pick up a computer fan (they're the same thing) and you'll only pay a couple bucks for it. Mount it under the amp and presto cooler amp and guess what else.... less draw (not much, but every lil bit helps).
Ampresearch
youngin?? lol you could be my son.solacedagony wrote:Let me go get my god dang ear trumpet before you speak youngen. *mutter mumble blah blah blah* lol
back on topic as said before these things do seem to be VERy power hungry. i run a 200 amp alt and a 200 amp fuse on my system and the voltage still drops from 14.8 into the low 12's during really heavy bass sessions
martin0804
No, the amp has never shut off in self protection mode yet, I guess I'm just a bit paranoid right now, I spend some pretty good money on all of this, and I really don't wanna break anything. I still need to upgrade the electrical system, will most likely be doing that tomorrow, as for the ventilation, the amp has the 4" of clearance overtop of it that it needs, its more along 10" or so.
the kicker zx amp do NOT have built in fans
hmm didn't know that, I just assumed they did since my KX did, so it seems that you're okay with the amp getting hot. Every amp does it, just don't touch it next time, cuz you might wish you hadn't.
