Wierd problem Do i need a new amp?
Post by CaptainPioneer »
Its entirely possible that it could be interference... but why would quality be amazing one minute and possibly impossible the next...?
Besides All of my signal cables are run down the passenger side of my truck and my power down the driver side.
COR UNUM VIA UNA - Jay Chmura
CaptainPioneer wrote:But does not do it if the Right side for the input on the amp is in... maybe what ill try to do is split the left signal from the hu and see if it still does it... If it does than that means it has to be the amp... if it doesnt than its either the signal wire or the hu...
Did you try swapping the right side to the left input to see if it still does it? That should help narrow the problem.
cargodz wrote:Did you try swapping the right side to the left input to see if it still does it? That should help narrow the problem.
I think at this point whole components need to be removed, starting with the head unit, swap it out and see what happens.
I don't have an extra HU sitting around... Well actually thats a lie... I do but i don't think it works anymore.. at least i don't think it outputs sound through the speaker outs... but i only need it to send a signal through the RCA's
I don't think I changed out the signal from the right to the left input on the amp... I'll try that. before I go swapping anything out... I will also buy a new set of wires as well... This just royally sucks because I just rewired this truck and hid all the wires with the beauty board... and that was a bitch...
Ugh.
use a laptop or something similar.
oh good call... Thanks I'll definitely try that... My laptop kicks Arse!
Well one thing is for sure... I will not be purchasing a new HU anytime soon...
I just pulled the trigger on a new March pump, Keg Coupler, and fitting...
I can't wait!!!!! Ahhh sorry .... I just kinda blurted that out!
loudwagon15s
Post by loudwagon15s »
does the noise occur without the rca's in?
If i dont have beer by next week its on.
TopCatXL
Post by TopCatXL »
Since I am the new pup on the block. I will earn my respect in the car audio world with you all. Respect given to you all.
