Audiopipe Amps?
suggestions on amps hmm.. for that price you could get a autotek MM4000.1 off ebay probably might be able to snag a bxi2006d crunch GP2500.1 umm... planet audio has some decent very small and strappable amps.
Schmuck
Post by Schmuck »
I have heard mixed opinions some say they do rated and are good for the money and some say they are crap. I did some research on Termpro and all the competitors using them seem to love them. Can anyone give me a deal on a better amp that would put out 2.5-3kwRMS for $500 max. And I am looking for 2 of them so maybe give me a little break on getting 2, shipped to Cantonment Fl 32533?
u want 2 2.5 to 3 kw amps for 500? jeeze poweraccustics or audiopipe it is lol
Schmuck
Post by Schmuck »
My bad for the miscommunication I want to spend $500 per amp so $1000 for both.
well then you got some options. in all honesty i would try to find a pair of MM4000.1s on ebay there great amps and there dual mono's so almost any load works on them.
Schmuck
Post by Schmuck »
I have not found them for $500 a piece so if you can find for that price or even a $100-200 more let me know.
[quote="Bwcad1"]i really doubt they will do rated power but what do i know ]
they have amps like that but they are called interfire.......
seriously though if you want a pair of the pipe amps give me a call at the shop and ill hook y9ou up
Schmuck
Post by Schmuck »
Are they good amps that put out rated power? I know that the GD-6001 is CEA compliant and will put out damn close to rated but what is there build quality? Also I was more so looking at the AP-30001 since it is a 3000 RMS amp but it does not state on there webpage if this model is CEA Compliant so I am worried about whether it puts out rated power. I have read opinions on termpro about the GD-6001 and they had nothing but good things to say but nobody has used the AP-30001, can you tell me if it is the same quality and if it is CEA rated, will it put out 3000 RMS? Also are there any better amps that I can get for around the same price and same power range? Looking to spend $1000 for 2 amps that will produce a true 2.5-3kw RMS @ 1 ohm.
Thanks for the help
the ap3000 is a dual mono block so its 3k watt rating is bridged at 2 ohms.....i have talked to other dealers using them and they swear by them. i havent brought one of them in yet because thats an assload of power most people dont want to do the upgrades to run it. i can get you a pair of them for about 900 shipped if you want them
Schmuck
Post by Schmuck »
Why does their website say that they are 3000 RMS @ 1 ohm if it does it at 2 ohm? And do you know if they are CEA Compliant?
