Help! I Need Some Advice On A Custom Instal
brandonjohns123
hey i have a 1996 hyundai accent 2 door i have 4 15 inch kicker cvr comp series n i am tryen to figure out a design for it im going to be removing the back seat to fit the subs i also would like to mount a 15" flat screen somewhere in the mix any body with any suggestions ??????????
brandonjohns123
brandonjohns123
breakjunki
brandonjohns123
i was thinking something along the line of removing the back seat then putting to 15" mono slot ported boxes back to back then kind build a slant to mount the monitor in then on the front of the box where i have to square everything off putting a couple 6x9's n component speakers in there along with a game system im not really sure how im gonna do it but any more sugestions would b great! :happy055:
breakjunki
skip the 6x9. go with a really nice front stage high powered component set up front. If you taking out the back seat either do a wall, Or keep the box running along the line of the rear deck. As far as the monitor, why not have a drop down ceiling one so you can see from the front..It kinda sounds like you might be using 2 prefab ported boxes side by side idea?? if so no.. You have a good idea with the back seat out you have alot of options, In a 2 door accent you could do a 4 -15 wall and It'd work pretty well.. have a fold down monitor on the celing up front, and amps, batteries etc in the trunk.. just my idea.
brandonjohns123
Ok so you wanna do something different... Here's a zanny thought: Take the 15" Monitor and put it on a hinge and swivel hinge so it stores horizontal, but has the ability to swinge up right and then to the left, right side or straight back... just somethin off the top of my head.
