Car problem......again
loudwagon15s
loudwagon15s
scotts1000rr
Definately get the battery checked too
Chris from MI
What kind of car is this and whats the year?
DO NOT disconnect the battery while the engine is running
I know people out there will say they do it all the time and yada yada but doing so can send a spike over 150 volts through the system, effectivly frying the alternator and or starter, along with your ECU and other stuff like that. Also with some of the newer cars this will throw a code and the car will not stay running even if the alt is good.
I would just pull that alt and battery and run them up to Autozone or whatever and have them check them out for you. Depending on the car, you can have them both out in about 15 minutes and then know what component is bad or that you need to look further into the electrical system. Good luck though.
the battery is used to start tha car, however if the battery has damaged cells from being drained too low, it will also prevent the car from holding a proper voltage rail.. and you'll see voltages like 11 or 10V.
The alternator does recharge the battery and supplies current to the car when the engine is running above idle RPM.
Here's the catch. If you ahve a newer car, and it sat for a period with a dead battery (similar to having no battery) the ECM in the car may need to be reset. You'll need to contact a dealer to find out if this is the case, but I know my Jeeps were like this, and showed similar behavior to what you're describing after the batteries were left disconnected for any period of time.
Also, your alternator is fine. If that were defective, you'd have a whole other set of symptoms.
My car is a 97 Mitsubishi Galant. Me and my father did the same thing today. Jumped it, it kicked over, but it stalls out and shuts off after about a minute. We called up an automechanic that he knows and he said once the car is on, you dont need the battery at all. He said it is probably frozen water in my fuel line, wich is causing gas flow to be cut off, which is why my car stalls out and shuts off. We had to push it about 3.5 miles from my school to my house :/
