most bass being locked in trunk...need some ideas
i drive a 99' buick century....im running a pioneer deh-p5800,a memphis mclass 500d and a 15" kicker cvr in a ported box....it gets loud on some songs but others it dont at all....it sounds like alot of the bass is being lost in the trunk and the trunk sounds like its going to blow straight off,my seats don't fold down or anything and the back of the seat has a plastic with foam covering the whole back seat.......does anyone have any ideas of what i can do to port the trunk or somehow make it louder because it came outta my brothers blazer and i know the system is capable of being pretty loud....any suggestions or ideas would be greatly appreciated....
thx justin
Lapeer,Michigan
thx justin
Lapeer,Michigan
- swimmerdude
Your car probably has a back deck that extends from the top of the back seat to the window line. That right there is the easiest way to get bass into the cabin. If there are speakers on the deck, i would remove them. The holes where the speakers were will act as ports and sound will come through the opening. Another thing you could do is use external round ports and have them go up to the opening on the back deck.
I did a 97 Century a few years back.
Pull the rear deck out and toss the 6x9's and the problem is solved...
Well the Buicks dont expose the speaker, they are behind a grill thats mounted to the rear package tray permanently.
So just take the rear seat out, rear back, pull the plastic, pull the deck. Remove and toss stock speakers, replace parts. Done...
No need to do anything else. The bass will improve many times over.
subster87
i had this same problem in my chrysler concorde, also another question just incase is the box almost wedged in beneath the back cash and floor? i had a box that barely wedged in my truck and literally created a barreer from the rear dash and rear seat. No air in no air out. If not the 6 by 9s comming out does help alot once i got my box to fit right and took those out worlds of difference, i think it helped with my back dash rattling too
mmmm inverted 18!!!!:bow
