MrSo0h0o wrote:well, knukonceptz doesnt have a 4 gauge amp installation kit.. could you guys list what i need to buy?
yeah they do, its a basic one that includes:
17 Feet 4 AWG Purple Power Wire (power wire)
3 Feet 4 AWG Silver Ground Wire (for your ground)
One Inline Fuse Holder w/ 80A fuse (for fuse at battery)
3 Gold Plated 4 Gauge Ring Terminals (for battery connection and others)
2 Gold Plated 4 Gauge Spade Terminals (other connections to amp and such)
basically if you have all that, you need remote turn on wire, which can be very small gauge, so that won't be spendy. You need some RCAs, i dont remember how many things you are hooking up but you need a pair for each channel and then you need the speaker wire.
i think the only other things that come with full amp kits are like split-loom for under the hood, and then probably wire ties and a bunch of different spade or ring terminals and such.
if you are hooking up more than one amp you will want to get a distribution block, check the "knu specials" i think they have a couple on there for cheap. if you have both amps next to each other you might want to use a distribution block for the ground too, to avoid a ground loop. might want to think about a fused dist. block for the +12v too.
