Amp keeps turning off
what ohm are the coils of the sub and what is the model number of the amp. it sounds like your loosing connections somewhere. something is coming loose.
audiobahn88
Post by audiobahn88 »
Alright well i called a guy at hellraising audio and he had me run some test on them and he also thinks they are wired as one of you said. My wiring is done right it was all professionally done so nothing is ducted taped my ground is sanded down and my power wire is 4 gauge along with my ground. I have a pioneer head unit. The guy told me it is not the remote because i ran the remote from the constant and it did the same thing. aw102n that is my model number for the subs. They are 450 rms a piece 900 peak power the amp is monoblock and 800 watts. They are dual voice coils also if you need more info to help me just write back thanks
Oh and i almost forgot its NOT going into protect mode its turning off completely then turning back on.
* 2" 4 Ohms Voice Coil
* PHAT 2” Foam Surround
* Magnet Weight: 80 oz.
Subwoofer Specifications:
* Subwoofer Size 10"
* Impedance 4 ohms
* Dual Voice Coil No
* Peak Power Handling 900 watts approx.
* RMS Power Handling 450 watts
* Woofer Surround PHAT 2" Foam Surround
well if all your stuff is hooked up right your amp has a problem.
audiobahn88
I think it is how the subs are wired inside the box. The guy at best buy who wired my subs said he only used one positive and one negative from each speaker and ran them parallel. The guy at hellraising audio told that is a very good possibility on whats wrong
u live maybe 10 mins from me y don't you bring it over to my place and ill fix it.
audiobahn88
Where do you live at and whats your name?
name is bill and im in medina.
audiobahn88
Where at in medina? Im justin by the way
audiobahn88
Where at in medina? What road
off lafayette.
