I noticed the D2400 only has 90amps (3x30amp) worth of fuses.
Anyone running this thing and not blowing the fuses like crazy?
the D1200 also has 3x30amps and I was wondering how they doubeled the output without needing more amperage.
If these things can put out around 1,200 watts@1ohm and only need 90amps to do it that wouldn't really be that bad compared to everything else I've been seeing rated at least 120amps 3 x 40amps or so.
I was also wondering if anyone had any idea about the MM 1000.1D from Autoteks fuse rating. I did a search on here and a few other car forums and couldn't find anything.
