oh sorry, I've sort of abandoned my PMs... I don't notice them. oops...toomanyamps wrote:I always stay away from the offbrands......You buy junk you get junk.....Well good luck if you buy it and damn geoman I have sent you messages of all kinds in reference to your amps get back to me with that
know anything about hitron amps?
Taco Supreme
- Member
the general consensus here is that the hifonics may be more than you need right now because it is stable to 1 ohm but will provide the correct power at 2 ohms while providing the flexability to upgrade in the future and at that price is going to be a "best buy" if you will
basically get it, it will do exactly what you want now and more in the future.....
toomanyamps
toomanyamps
Taco Supreme
- Member
alright, so it might be interesting trying out a square sub thats not kicker, but if i'd rather play it safe, would this sub be better? and if i understand (which im not sure i do) it would get better power....rms @ 2 ohms for the amp is 500, while this is a dual 2 ohms sub with an rms power handling of 600 watts. so that would match up pretty well together right?
http://www.sonicelectronix.com/item_6613.html
and once again, in case you need the amp specs again, the amp was
http://www.sonicelectronix.com/item_6556.html
Taco Supreme
- Member
