not really.....it is easier if its double din usually if you take apart an 8" wide screen its a perfect fit to get the screen installed flush in the radio opening.....his was din and a half and i used a 7" screen......the coolest tv install ive done to date though is the 40 lcd in the back of that green xb.....
Hay smoker if you want someone to clean up your soundsolution myspace page a little (get rid of the stupid links that poped up when you designed the page) I can. Its pretty easy.
I can talk you thru it, or you can temp change your password, I will do it and then you can change it back. Its pretty darn easy, heck I did it to mine.
ZeroAccess
