Ok Just recieved some new things but am confused
warsoul
Post by warsoul »
First a List of everything
Headunit
http://www.crutchfield.com/S-VaCGnrnQC2 ... 113KDCX990
Amps
http://www.crutchfield.com/S-VaCGnrnQC2 ... =108R7541A (4 Channel)
http://www.crutchfield.com/S-VaCGnrnQC2 ... oka+EL1500 (Mono Amp)
Speakers
http://www.crutchfield.com/S-VaCGnrnQC2 ... I=108507CS (to put in kickpanels)
http://www.crutchfield.com/S-VaCGnrnQC2 ... =1086012SI (Rear Fill)
Wires
http://www.crutchfield.com/S-VaCGnrnQC2 ... 211PSK04BM (Mutli-Amp Kit)
http://www.crutchfield.com/S-VaCGnrnQC2 ... =211UC1250 (12 gauge Speaker Wire)
http://www.crutchfield.com/S-VaCGnrnQC2 ... =211ZN5260 (Patch Cable to hook up amp to headunit)
http://www.crutchfield.com/S-VaCGnrnQC2 ... =211ZN7460 (4 Channel patch Cables to hook up from Amp to Back of headunit)
Alright... that's all the new stuff
First thing I'm confused about is the wiring... I look at the wiring harness that came with the CD Player and read the Manual
These are the wires that confuse me...
Blue/White (Power Control Wire) When using the optional power amplifier, connect to its power control terminal
Blue (Motor antenna control wire) Depending on what antenna you are using, connect either to the control terminal of the motor antenna, or to the power terminal for the booster amplifier of the fils type antenna
I have a power antenna
Pink/Black (External Amplifier control wire) To "EXT.AMP.CONT." terminal of the amplifier having the external amp control function
I know an amp needs a remote turn on ... I've read that its the blue wire... So is it the blue one or the blue/white one?
What does this Pink/Black wire do? I have RCA Patch Cables to hook up from the amp to the back of the Head Unit to control the speakers. Do I have the wrong idea about the patch Cables and I'm supposed to use the Pink/Black wire instead?
Last but not least... Since I have TWO Amps... how can I hook both up so that I can control both from the Headunit? I know the Infinity ones speaks about daisy-chaining but haven't got a clue what it means.
Thanks for any and all help you can provide.
You use the blue/white wire for a remote turn on. Ignore the pink/black one.
Daisy chaining is easy. Tale the remote wire and hook it up to one amp. Now take a piece of wire and connect this amps remote turn on lead to the other amps turn on lead.
warsoul
Post by warsoul »
will I be able to control both amps from the headunit?
Thanks for the quick reply!
What do you mean control? What are you trying to control?
warsoul
Post by warsoul »
ok so I use the blue/white wire as the remote turn on wire...i splice it and hook it up to the 2nd amp also ok I got that much.
Now as far as being able to control the Amps with the headunit...??
warsoul
Post by warsoul »
Control the Fade, Balance and things like that
If a song has more bass than I want I can turn it down on the Head Unit rather than on the amp itself
See all of my speakers will be hooked up to the 4 channel amp not directly to the head unit. So I need to be able to control the trebel mid bass and all those things from the head unit...
I was wanting to find out how I can control Both amps with the head unit.
Yes, yes, you control all of that from the headunit. If you want to control everything seperate, you just need 3 pairs of RCAs - front, rear, and sub.
