weird problem!!! plz help
recently i've purchased 4 pioneer 6x9" speaker
it's rocks amazing but when i hook up them on amp in parallel i heard shitty sound
so i decided to check the polarity but i found there is nothing wrong
but when i do the speaker test with battery :
(i connected battery direct to the speaker )
2 speaker move upward and 2 speaker move downward !!!!!
i searched about this problem and i found this article on basic car audio
(http://www.bcae1.com/speaker.htm
NOTE:
I've heard about at least one speaker manufacturer that makes their drivers with the polarity opposite of the above diagram. It is a company that makes drivers for use in commercial PA cabinets, so you won't likely see them in cars.)
so when i connect 2 speaker parallel that move downward on amp channel 1
and connect other parallel that move upward on amp channel 2
the sound is amazing!!!
so what suppose to do now?
is keep it
or
change the original polarity for the speaker move downward
and plz can i know that wrong polarity harm the speaker?
NOTE:
is keep it
or
Wrong polarity wont harm a speaker, unless its a DVC and you have each coil wired differently.
Whats happening is one or more of your speakers is running out of phase.
I havent ever seen a manufacturer make that kind of a mistake before.
Quadruple check YOUR wiring, as Im positive thats where the problem is.
heyy people i said that the wiring is not my problemsmoker wrote:are you running a set of wires back to the amp for each individual speaker? with coax and triax and god forbid the 4 and 5 way 6x9's that pioneer makes ive seen phase shift issues when people daisy chain the wire from one speaker to the next....
I CONNECTED BATTERY TO THE SPEAKERRRRRRR DIRECTTTTTT
NEGATIVE WITH NEGATIVE AND POSITIVE WITH POSTIVE
TWO SPEAKER MOVE UPWARD
AND 2 SPEAKER MOVE DOWNWARD!!
(4X PIONEEER 6X9" 350W 3-WAY TS-A6971E)
AND YES IT'S ORIGINAL
I BOUGHT THEM FROM PIONEER DISTRIBUTORS
tobler wrote:heyy people i said that the wiring is not my problem
well i guess you got this shit all figured out then dont ya......
