do i need to upgrade my alt
audiofreak12
I was wondering if i was in need of an alternator upgrade. I am running a PPI pc275 amp, an Alpine V-power amp, and possibly one more amp if i get my rear mids. I need to know if i am going to have to upgrade my alt or do I just need to just get a better battery. The battery and the alt are stock. Its on an 02 envoy if that matters.
we are running a jl 500/1 a jl 300/4 an extant 2180 bridged into two channels for a total of 1160 watts and have no problems with the stock alternator and have no caps or other upgrades. this is in a 2000 chevy silverado ext. cab. and yes it rocks. just dont listen with the engine off for too long or youll need a jump
It all depends on the vehicle. If the vehicle comes stock w/ a higher amp alt (i.e. trucks) then you may not. But on most passenger vehicles/cars, you will need to upgrade.
"just dont listen with the engine off for too long or youll need a jump"
Common sense, when the engine is off, the alt. isnt keeping the voltage up on the battery...thus killing it
TEDD
TEDD
6three6mafia6
audiofreak12
f-onefifty
the only way that would work is if the system isn't being driven at full output, or anywhere close to it with 2000 watts on a stock alternator.
a 100A alternator produces a peak of 1200 watts of power. usually 50-80% of that is used by the car itself.
The only way you get by using large amplifiers without clipping is by using only a small portion of the amplifiers' output since a "1000wRMS" amplifier only produces 1000 watts RMS @ full output, and every +10dB down from that full output is a tenth the amount of power coupled with the dynamic nature of most audio signals being produced by the amps.
