I'm looking to power 2 RE SE 12" dual 4ohm by 1 class D mono amp.
I've looked at wiring diagrams (http://mobile.jlaudio.com/support_pages.php?page_id=161) and I can wired them series/parallel or parallel/parallel. The frist would be 4ohm load and second 1ohm (I'd go for second to save money on the amp).
The subs are rated 600wrms each, so really I should look for an amp capable of 1200wrms at 1ohm. Then the 1200wrms would be divided in two, thus 600wrms to each sub, yes?
Also with the wiring, there will be 2 wires (+ an -) coming out of each sub, do i just connected the two + to the + terminal of the amp and likewise for the -?? This diagram (http://mobile.jlaudio.com/graphics/Supp ... llel_2.gif) shows them linked with dots, do I need some sort of block or just run the wires straight to the terminals???
Will the power be distributed 50/50 to each sub??
Sorry for what probably seems an obvious question
