How Two Hook Up Two Amps....
xmajinsoljahx
I have two amps...they only have 1 pair of rca outputs...how do I hook it up using Y-Cables....also how do I hook up the remote turn on wire for both amps?
If you already have an rca splitter (i think thats what u mean by a y cable) then run the rca's from the back of the deck to them, and then get 2 other sets of rca's and hook them up to the opposite side of the splitter and then to the amps.
As for the remote turn on, just run one wire to the first amp, then take another wire and hook it from amp 1 to amp 2.
TEDD
TEDD
xmajinsoljahx
ok...
ok one question...my deck on has 1 rca output...does that matter or were u refering to that kind of deck...mine does have two pairs one 1 pair...ok about the remote turn on....I hook the remote lead wire to from the deck to the 1st amp(Hook it to the remote hook up)...Then where do I put the 2nd wire to goto the 2nd amp? can I put it in the same slot in amp 1 and lead it to amp 2?.......also I have a 1990 Dodge Ram that im putting this in...with hooking up two amps...do you think i need a new alternator? I don't know the specs on the alternator, but my truck used to be a forest ranger truck and im sure they upgraded the alternator becuz they had cb's and radars n junk in it...the only thing i replaced on the truck was the paint and engine. so do u recomend i change the alternator?
WHOAA....im confused now.......on the back of your head unit you should have at least on pair of rca connections a red and a white...this equates to one pair. if you need to split that you can use a y cord to branch each side (red and white) into two. make sure that your y cord is one male into two female. then you can simply take two seperate rca cords and connect them....a red from each cord into the y cord where you split the red connector behind the head unit and a white from each cord to where you split the white connector behind the head unit. then simply connect the red and white from each cord to its apropriate amplifier. keep in mind you will experience signal loss this way. and yes you can daisy chain the remote lead.
xmajinsoljahx
xmajinsoljahx
