Mono Amp question
Mercedesbends69
Id look for a JBL 600.1 or 300.1. Either would give you good results in the right box. If you're planning on going sealed. Go for the 600.1. It's slightly more power than you actually need, but it's such a minimal amount of extra power that you should be fine with the gains set right. With a ported box you might as well go with the 300.1 which would give you less power than the subs are rated for, but should still reach full excursion. With the 300.1 and a ported box, you should go to http://www.partsexpress.com and pick up the 20hz F-mod since the JBL BP series amps lack a Subsonic Filter. Either choice would be perfect in your case. Look for some refurbs JBL's online. They're good quality dependable amps and can be had for cheap.
I got the 2 subs, a bandpass box and an amp for $250... like i said the amp was bunk but the box itself cost more than $250 so I thought it was a steal... Ive never heard too much negative on JBL so I didnt want to pass it updmeyer07 wrote:If you don't mind me asking... What did you pay for them :) . Just curious.
The first thing you will want to do is ditch that box ASAP.
Prefabbed bandpass boxes blow goat balls. Sorry to break it to you.
A properly build Sealed box will sound absolutely flawless to you when compared to the bandpass.
As for the Amp... I know the JBL BP series amps everyone is reccomending. They are good amps, but are becoming HARD to find.
What kind of head unit do yuo have?
Im going to start reccomending ALpine amps I think for people on a budget. THey dont look all to bad, its Alpine- and the price is decent.
