My buddy and I take apart half the car to run the new cables. I bought 4 gauge wire for both the new power and the new ground. Got the cable all through and set up for the hookup to the amp. Well first of all, the remote wire sensing that the JL amp has through the RCA's didnt work. I connected a physical remote wire to the amp and great, it's staying on. I go to connect the subwoofer wires and the rca's to the amp expecting a nice deep bass to no avail. Nothing. I tried bridging the speaker wires, putting all the gains up halfway, messing with the high pass low pass settings, putting the rca's to amplifier out and in. Nothing. I turn up the volume and the only thing that happened was the ohm light kept going on. So at this point I got mad.
Now some of you may remember I had a problem with my eclipse amp frying. Turns out what fried was the ground wire. For some reason the 8V preout on my eclipse 8445 was too much and fried the thin ground wire (300w wiring kit used for over 3 years with no problems till I switched to a 8v preout HU.)
I figure since the original ground wire got fried, I may as well call it a nite, throw in the old amp and see if that works. Nope. Amp kept shutting off like before. Not to mention that in the span of an hour, my battery (which is barely 2 weeks old) discharged. I think I may have fried my alternator as well somehow. At this point im so fed up that I dont know what to do. Help!
