What do you think about the New Orion Amps?
NeillBarber
Post by NeillBarber »
Don't quite get your question.
Whats the concern you have with the 600D?
NeillBarber
SACHEL
Post by SACHEL »
is it worth buying? its not one of the high wattage amps talked about so i was wondering if its as good as the higher orions
NeillBarber
It's just as nice as the others, but alas most people want big amps.
Your application...ie:what you'll be pushing and your music taste. Will determine wether or not it's a good deal for you. Im selling my new D2400's for $275 each.
So just depends on your situation.
NeillBarber
SACHEL
Post by SACHEL »
looking for mostly bumpin not as much sq, but im tryin to find an amp that puts out 500 rms at 2 ohm at this point and this is the cheapest amp.
NeillBarber
True.
But if you want your equipment to last forever I would use a larger amp so it's not running at 80+ precent capacity.
The D2400 will do 600 at 2ohms and have tons of head room.
PS the 600D model is a couple of years old. The replacemtn is now the D1200.
NeillBarber
