12v Case Fans
12v Case Fans
Post by audiobass10 »
I was planning on building an amp rack and adding 2 12v case fans inside to keep the amp cool. Do these amps run off of battery alone or do they require wiring as well?
Dustin from Huntsville
Did you mean to ask if the case fans run off a battery?
You need to power the case fans by tapping off a 12 volt source. If you have a distro block going to your amps, just tap off of that.
