I could use some help figuring out the best way to wire my set-up. I have 1 Soundstream Van Gogh VGA500.4 amp with the specs listed below.
RMS @ 4 OHMS: 125W x 4 CH
RMS @ 2 OHMS: 250W x 4 CH·
RMS BRIDGED POWER @ 4 OHMS: 500W x 2 CH
I have 4 8ohm (100rms / 200max) midbass speakers and 2 8 ohm (100rms / 200max) compression horns. Can you help me figure out the best way to wire them to my amp to get the most watts out?
Thanks for your help.
Need help wiring my set-up....
Probably bridged to 2 channels with everything in parallel.tmorefi wrote:I could use some help figuring out the best way to wire my set-up. I have 1 Soundstream Van Gogh VGA500.4 amp with the specs listed below.
You could also try mids on 2 channels, tweets on 2 channels.
