Wiring kit
daykareboards
Wiring kit
I'm running Rockford Fosgate wires for my main amp, but cash is really tight right now (laid off) and i need a kit for my amp thats going to be powering my door speakers...i'm only gunna be pushing 100x2 tops. is that cheap wiring kit Scoche alright for that? or should i wait to grab some better 1's?
another Q. i was hooking up a system for my buddy and he's got 2 amps so i ran the RCA's to one of the amps inputs and through the RCA output on the same amp to the other amps inputs and they are sounding horrible...the subs are near loud enough and the only thing coming out of the speakers is a popping and static sound...any suggestions?
http://www.KnuKonceptz.com. You only need an 8 gauge kit.
daykareboards
daykareboards
justin, in the question u answered was another question i had about a buddies system...i have the RCA's coming from the reciever going to the more powerful amp and then the outputs on that amp are going to the inputs on the speaker amp... i had it like that then i even tried switching it and its still doing the same thing... so right now i have no idea...i checked all my leads and grounds...everything is fine in that department.
