Rated Power Front/Rear Channels
50 W x 4 @ 4 Ohms RMS
100 W x 4 @ 2 Ohms RMS
150 W x 4 @ 1 Ohm RMS
200 x 2 W @ 4 Ohms Bridged Mono
300 x 2 W @ 2 Ohms Bridged Mono
Sub Channel
300 W x 1 @ 4 Ohms RMS
600 W x 1 @ 2 Ohms RMS
800 W x 1 @ 1 Ohms
Total Power 1400 Watts
Bridgeable Yes (front/rear)
Crossover Controls Front Channels
High-Pass (HP): 40-400Hz 12db or 24db/Octave Linkwitz-Riley
Low-Pass (LP): 40-400Hz 12db or 24db/Octave Linkwitz-Riley
10x crossover switch
Rear Channels
Sub Channel
Low-Pass (LP): 32-250Hz 24db/Octave Linkwitz-Riley
Infrasonic filter: 28Hz fixed
Tone Controls Bass: 0dB to +18dB @ 35-75Hz (sub channel)
Signal Input Low level: 3 RCA pair
Signal Input Switch: 2/4/5
Signal Output n/a
Power Input Connector Block
Power Wire Gauge 1/0 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 12 AWG
Heat Sink Type Cast aluminum
Cooling Fan Cooled
Remote Controls ParaPunch Bass EQ (included with cable)
Visual Indicators Power On
Thermal
Output Short Circuit
Fan On 3 Stage Termal
Low B+ Voltage (below 11VDC)
5-channel Level Monitors
Circuit Topology Class Front/Rear Channels
Class A/B
Sub Channel
Class BD
Frequency Response Front/Rear Channels
20Hz to 20kHz +/- 0.5 dB
Sub Channel
20Hz to 250Hz +/- 3dB
Dimensions 2.6 x 12.8 x 23 (in)
6.6 x 32.51 x 58.42 (cm)
Weight 13 Lbs.
(5.9 Kg.)
or
FOR MORE INFO:
http://www.rockfordfosgate.com/products ... cale=en_US
