whine and pop
hes supposed to own his own shop i figured he would have checked the ground issue ;)
DC AUTOGROUP
Post by DC AUTOGROUP »
No the grounds are fine the amp,and the batt cap im running 0ga streetwires wire 200amp breaker the amp gets a little warm but thats it ...im going to take
to amp and get it swaped out ...so im thinking my be the amp
i have a jl 1000@1 im going to try i will let yall know
thanks for the help yall :thumbsup
i hightly doubt its the amp but i guess thats your choice!
lotas
Post by lotas »
Yeah I'm with Bill, that doesn't really sound like an individual amp issue. But who knows, maybe it is.
Just for clarification...that 0ga you are running is under the hood and grounding the amps right? And how are the grounds connected? Are the connected firmly and securely or are they half-assed?
DC AUTOGROUP
I used streetwires ground blocks also .....
ok so i swaped out the amp and its working fine.....about one hour now
so thanks for all the help yall
oh and i thing im going to go with a kole 3000d insted haha just playing
Robert Wollenberg
Post by Robert Wollenberg »
I still bet you have a grounding issue. Have you checked for ground potential? I believe that's what it's called.
Post by High Society »
What amp did you change it out to?? And have you checked the amp to see if there was anything blown??
DC AUTOGROUP
i used another hifonics amp
the ground were good but when i took the amp off the back wall it smelt burnt up...but my jl 10001 smelt the same after running it but it still works
if the jl was doing the same thing there is some serious wire problem or something. unless your clipping the hell out of them.
Did you upgrade the electrical system? I can't memeber if you said you did or not.
