closed. sorry about lack of info, work has got me tied up i will post info again when i have time. (i only do those models because i was trained by a friend at best buy on those specific models)
you will definately need references and such to get anywhere with that.. good to see you can fix the problems, but people arent just goin to want to send you their deck without knowing for sure you can do it.. so... good luck!
im gonna call bs no offence but everything seems suspicious with this your name the fact you only do 2 models. i have an 8400 with problems but im way to leary to send it to you.
Since when does BestBuy employees do internal headunit modifications?
My friend at Walmart showed me how to modify my Lightning Audio Fast&Furious 250watt amp to put out 6kw. All I had to do was wire it up to a lightning rod and wait.
