Sub enclosure ideas
brownbob06
Sub enclosure ideas
Post by brownbob06 »
I need a clean way to install my subs and amp in a my 93 Civic LX. They are 12 in. Kicker Comp subs, and a Kicker KX 250.2 amp....just want it to be clean, and nice looking :D whether I use fiberglass or carpet.
dkguitarist
Post by dkguitarist »
false floor for the amp, and make a box for the sub, then build a false face for it to make it look flush with the sub maybe??
brownbob06
I already have the amp mounted where the spare tire should be with plexiglass over it if that's what you mean, I just want something a bit cleaner.
dkguitarist
have any pics of that setup? worse comes worst, just build an "amp rack" and plexi it, or sink it in and make it look flush.
if its got enough airspace... make use the spare tire well for a encosure (use fiberglass) and then build a false floor and hide the amps. thats my plan for the summer... at worst you'll be able to see amps. subs will be hidden.
OnYrMrk
Post by OnYrMrk »
my sub is hidden, and fires through the rear package tray...amps are exposed, but they are fastened down with non-phillips/flathead screws
brownbob06
These all sound like good ideas, and I'll prolly try some of em, but the only thing about using the spare tire well is I decided I want to build my box exactly as the manufacturers specs to get the best sound possible.... actually, I guess that wouldn't be a problem, I could just build the box in the spare tire well...I'll see, and I'll try to get pics of my current setup to put on here so you can see it.
