gain controls
gain controls
on my amp i have "input sensitivity", thats gain right? so if that is all the way down is the amp still giving rms power? or do you have to turn it up all the way to get rms power?
Robert Wollenberg
All head units are not created equal, for that, they put a gain control on amplifiers. All the gain is for is to match the input stage of the amp to the output voltage fo the head unit. If your head unit puts out 200 milivolts, you're going to need to crank up your gains. If you have a head unit that puts out 2 volts, you can probably turn your gain all the way down. If you have high output from your head unit and you crank your gain up what you're doing is limiting the headroom of the amplifier.
Look at the voltages marked on the amp or in the owners manual for the gain of the amp and adjust it according to the output voltage of the deck.
Robert Wollenberg
depending on your amp, too much voltage into your inputs can burn out that stage of your amp. But otherwise, the only real stress on your amp is the load you put on it on the output. And whether or not it's being properly cooled and all that. Assuming you don't have it hanging upside down under your rear deck or something like that, you should be fine.
Robert Wollenberg
yeah i'm running boston comps up front and 2 10w3v2s, dual 4 ohm, bridged . . as for how they are wired i don't know because when i got my jl 500 checked out he wired the subs, umm . . positive and negatives are connected on each sub, then the other set of positive and negatives are ran to the terminals, out side of the box both positives and both negatives are twisted together and put in the bridged outputs on the amp.
Robert Wollenberg
if they're wired how it sounds, you're running 2 ohms to the amp. If you're having overheating problems, that might be it. You have everything paralleled. You need to series either the voice coils of each sub or the subs themselves. Like this ... http://www.usspeaker.com/speaker%20wiring-1.htm
The last one on the page.
Robert Wollenberg
